El Hombre de las Sombras BluRayRip AC3 5.1 | Sore ga Seiyuu! English Subbed | Batman v3 003 (2016) (Webrip) (The Last Kryptonian-DCP).cbr (- Nem -)
+ ShareSpark.net »  :::: Miscellaneous » Mobile Downloads » Android Applications
|- X-plore File Manager v4.01.10 [Donate]
Amazon Pantry Offer
September 11, 2018, 05:22:03 PM
  • Conqueror
  • Elite Forces
  • Thank You: 493
    41%
  • Country: in
  • Topics: 490
  • Hit ThanX Button 🔳 N Repute Button 🔳
Requirements: 4.1+
Overview:
X-plore is dual-pane file manager with tree view, LAN/FTP/Root/Clouds and more.
Description
Highlights:
● Dual-pane tree view
● Root, FTP, SMB, Sqlite, Picasa, Zip, Rar, 7zip explorer
● Cloud storage access: Google Drive™, Dropbox, Box.net, Mega.co.nz ***, SkyDrive, Webdav, Yandex.disk, Ubuntu One, SugarSync, Dump Truck, Copy.com
● SSH File Transfer (SFTP) and SSH Shell - _http://bit.ly/xp-ssh ***
● Application manager
● WiFi file sharing *** - _http://bit.ly/xp-wifi
● Manage files from a PC web browser *** - _http://bit.ly/xp-web
● Favorite folders
● Built-in viewers for images, video, audio, text
● Hex viewer
● Fast Image viewer with zoom and slide to previous/next images
● Thumbnails for images and video as well as for various file types (depending on associated application)
● Multi-selection - always available, yet not disturbing
● View APK files as ZIP
● Share - send files by Bluetooth, email, or whatever the device supports, from any location
● Configurable buttons and key shortcuts
● Seamless work with Zip (as if it was normal folder)
*** marked features are paid - they require donation
X-plore allows you to see inside of your Android device. And also outside.
This is a dual-pane explorer, there are two folders shown at same time, and common operation such as copying files are done from one pane to another.
And X-plore shows folder hierarchy in a tree view for clear orientation and fast switching to other location.
You may explore internals of the device, and if you're power user and have your device rooted, you can make changes to system data - backup files, remove unwanted applications, etc.
If you're standard user, you may choose to hide internal memory from view and be sure not to mess with system.
You can comfortably see contents of mass memories on your device, or possibly attached USB memory stick.
Simple app manager allows to see, run, copy, share, uninstall and further explore installed applications.
WiFi file sharing
Access files on your Android device from other Android devices over WiFi.
Access from a PC web browser
Manage files on your Android device from your PC.
Access to FTP and FTPS (secure FTP) servers is supported.
Multiple servers may be configured.
X-plore can display shared folders on other computers in LAN (local area network).
The system allows access to shared folders on computers connected to LAN, or even remote server if it supports SMB protocol.
X-plore can access various web storage "Cloud" servers, and access their files.
You need to have account in supported web service, then you can access your files stored online through X-plore.
Supported is also SSH File Transfer (SFTP) and Terminal shell emulator.
Main operations are related to managing files and folders - viewing, copying, moving, deleting, compressing to Zip, extracting, renaming, sharing, and more.
Picasa albums
X-plore can list images in Picasa albums, download them, create albums, upload and delete photos, edit captions.
SQLite database viewer
X-plore can show SQLite database files (those with .db extension) as expandable list of tables, each table containing list of rows and columns with database entries.
Main interaction is done by touch screen, clicking on folders or files to open files, or long-click to open context menu which contains options which can be done on particular clicked item, or multiple selected items.
Multi-selection allows to do operation on more files at once. Files can be selected by clicking check box. It is also possible to select all files in a folder, or clear selection, by clicking parent folder's check box.
Opening file may mean to use one of built-in viewer for most popular file types: images, audio, video and text.
Or you may configure X-plore to use system application for opening files, in which case system-predefined application that can open particular file is launched.
Archives (currently supported are Zip, Rar and 7zip) are displayed as other folders.
Additional interaction is possible by button bar, which is between two panes, and is fully configurable.
WHAT'S NEW
Improvements in ID3 tag editor
This app has no advertisements
More Info:
http://play.google.com/store/apps/details?id=com.lonelycatgames.Xplore
Download Instructions: Donate features Unlocked | Drive Cloud works | AOSP Compatible | Analytics disabled
Patched:
Mirrors:
Untouched:
Mirrors:
« Last Edit: September 11, 2018, 05:30:46 PM by JackRoSe »
Hit Thnx Button 🔳 N + Repute Button 🔳 Always Appreciate UploadeR 🤗 GiVe Respect GeT Respect :yu:
Thanks given by:
September 25, 2018, 04:06:25 PM
Reply #1
  • Legend Member
  • Thank You: 1318
  • Topics: 877
Last post May 08, 2011, 12:32:34 AM
by Symbi
Last post November 21, 2017, 09:17:30 PM
by JackRoSe
Last post December 02, 2017, 09:56:32 PM
by JackRoSe
Last post December 03, 2017, 09:20:33 PM
by JackRoSe
Last post December 14, 2017, 09:56:57 PM
by JackRoSe
