Junichi Suwabe | ', CENTER);" onmouseout="return nd();">Gomorra la serie 3 Episodio 3x01 mp4 torrent icb torrent | Lolo - Drei ist einer zu viel
+ ShareSpark.net »  :::: Hollywood Zone » Hollywood Movies (Pre Releases)
|- Alpha (2018) 720p HDCAM x264 (WM-Spam) [2.44GB+565MB=1 Link]
100% Recharge Offer
September 18, 2018, 08:25:58 PM
  • Team SSX
  • Special Member
  • Thank You: 122
    18%
  • Topics: 493
  • Upgrade My Reputation
IMDB:
http://www.imdb.com/title/tt4244998/
Release Info:
Complete name                            : Alpha.2018.HDCAM.x264.2.44GB.By.Rj.Rabasha.mp4
Format                                   : MPEG-4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/isom/avc1)
File size                                : 2.44 GiB
Duration                                 : 1 h 29 min
Overall bit rate mode                    : Variable
Overall bit rate                         : 3 882 kb/s
Encoded date                             : UTC 2018-08-19 08:40:57
Tagged date                              : UTC 2018-08-19 08:40:57
Writing application                      : TMPGEnc Video Mastering Works 6 Version. 6.2.2.29
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : [email protected]
Format settings                          : CABAC / 7 Ref Frames
Format settings, CABAC                   : Yes
Format settings, RefFrames               : 7 frames
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Source duration                          : 1 h 29 min
Bit rate mode                            : Variable
Bit rate                                 : 3 661 kb/s
Maximum bit rate                         : 18.0 Mb/s
Width                                    : 1 072 pixels
Height                                   : 592 pixels
Display aspect ratio                     : 16:9
Frame rate mode                          : Constant
Frame rate                               : 29.970 (30000/1001) FPS
Standard                                 : Component
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.192
Stream size                              : 2.30 GiB (94%)
Source stream size                       : 2.30 GiB (94%)
Writing library                          : x264 core 148
Encoding settings                        : cabac=1 / ref=7 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=1 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / slices=1 / nr=0 / decimate=1 / interlaced=0 / minigop=0 / stitchable=1 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=3661 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / vbv_maxrate=18000 / vbv_bufsize=18000 / nal_hrd=vbr / filler=0 / ip_ratio=1.40 / aq=1:1.00
Color range                              : Limited
Color primaries                          : BT.709
Transfer characteristics                 : BT.709
Matrix coefficients                      : BT.709
Audio
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Codec ID                                 : ac-3
Bit rate mode                            : Constant
Bit rate                                 : 224 kb/s
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 144 MiB (6%)
Service kind                             : Complete Main
Default                                  : Yes
Alternate group                          : 1
Subtitles                                : N/A
Plot: An epic adventure set in the last Ice Age, ALPHA tells a fascinating, visually stunning story that shines a light on the origins of man’s best friend. While on his first hunt with his tribe’s most elite group, a young man is injured and must learn to survive alone in the wilderness. Reluctantly taming a lone wolf abandoned by its pack, the pair learn to rely on each other and become unlikely allies, enduring countless dangers and overwhelming odds in order to find their way home before winter arrives.
Genre: Adventure | Drama | Family
Directed by: Albert Hughes
Starring: Kodi Smit-McPhee, Natassia Malthe, Leonor Varela
Note: - Watermark Spam In This Movie
1GB Each Part
http://openload.co/f/FTMfzUMtEpM/Backup1.Alpha.2018.HDCAM.x264.2.44GB.By.Rj.Rabasha.part1.rar
http://openload.co/f/BRrZat2EZIg/Backup1.Alpha.2018.HDCAM.x264.2.44GB.By.Rj.Rabasha.part2.rar
http://openload.co/f/qDmjxIdpCcU/Backup1.Alpha.2018.HDCAM.x264.2.44GB.By.Rj.Rabasha.part3.rar
1GB Each Part
http://bdupload.info/vlmyb3m6yzrx
http://bdupload.info/qn546p0x37vw
http://bdupload.info/v8dr41hc38vv
1GB Each Part
http://www.indishare.me/65j8312cbnt9
http://www.indishare.me/fq1fxdqvw7dt
http://www.indishare.me/ynv0did7sf7e
1 Link 2.45GB
http://uptobox.com/xu6ht52u5yqw/Backup1.Alpha.2018.HDCAM.x264.2.44GB.By.Rj.Rabasha.mp4
1 Link 565MB
http://vidoza.net/92ty10kjxh2r.html
Tags: alpha
Last post September 18, 2018, 07:03:44 PM
by Rabasha
Last post September 18, 2018, 06:40:17 PM
by Rabasha
Last post September 18, 2018, 09:12:14 PM
by Rabasha
Last post September 20, 2018, 05:09:26 AM
by Rabasha
Last post September 24, 2018, 04:05:44 AM
by Rabasha
