Медики Чикаго / Chicago Med [04x01-03 из 20] (2018) WEB-DL 720p | Jaskier | The Good Place - Saison 3 (Ajout de l'Episode : 4) (Web-DL) | Joshua Jackson
+ ShareSpark.net »  :::: PC Applications and Games » PC Applications
|- Directory Lister Pro 2.30 Enterprise Multilingual
Mastercard 10% Off
October 03, 2018, 05:36:30 PM
  • Royal Member
  • Thank You: 2
  • Topics: 975
Directory Lister Pro 2.30 Enterprise Multilingual | File size: 11 MB
Directory Lister Pro allows you to list files or print folders, that is to create and then save, print or send via e-mail list of files from selected folders on hard disks, cd-roms, dvd-roms, floppys, USB storages and network shares. Listing can be in HTML, text, CSV format (for easy import to Excel) or stored directly to a database. Directory Lister Pro is one of the best and at affordable price application from a wide category of directory printers.
Additional columns you can include when you print folder list When you print a file list, you can include standard file information like file name, extension, type, owner and attributes as well as executable file information (EXE, DLL, OCX) like file version, description, company.
Also multimedia properties (MP3, AVI, WAV, JPG, GIF, BMP) like track, title, artist, album, genre, video format, bits per pixel, frames per second, audio format, bits per channel can be listed.
Another set of columns you can print is for Microsoft Office files (DOC, XLS, PPT) so you can see document title, author, keywords etc. without opening these files one after another.
For each file and folder it is also possible to obtain its CRC32, MD5, SHA-1 and Whirlpool hash number so you can verify the file has not been modified.
Print files in folder - further customization
Extensive number of options allows you to completely customize the visual look of the output. You can set sorting for files and folders so they are always displayed as you want. You can define column order so the most important columns are immediately visible. International display format options allows you to adjust the output for your local needs. Listing can contain links to actual files and directories so you are able to put the listing on a web page with clickable contents.
HTML display style is fully customized - you can change background color, separate style for header, directory rows, odd and even file rows and for surrounding frame.
You can limit the files list by applying a filter for filename, date, size or attributes.
Directory Lister Pro can also be integrated into the context menu of Windows Explorer so you don't even need to open the application to generate listings.
Command line interface is supported for automated listings that can be run from Windows Task Scheduler.
Check folder size or find large folders
With Directory Lister Pro, you can also find out what is the given directory size, sort by folder size and check which folders occupy the most space on your disks. You can also find the largest files on your PC by using size filter options.
Whats New
http://www.krksoft.com/Whatsnew.php
HOMEPAGE
Download From Rapidgator
http://rapidgator.net/file/f2d8a62569733e12f45d541263ea49d0/BaDshaH-Directory_Lister_Pro_Enterprise_Edition_v2.30.rar.html
Download From Nitroflare
http://nitroflare.com/view/6117F4F12F790F0/BaDshaH-Directory_Lister_Pro_Enterprise_Edition_v2.30.rar
Download From Uptobox
http://uptobox.com/sbkdina0rxdt
Last post November 26, 2014, 10:23:11 PM
by ♫♪ RΩCK BΩY ♥♫
Last post June 15, 2018, 10:46:00 AM
by kiteflyy
Last post October 04, 2018, 11:14:02 AM
by BaDshaH786
Last post October 05, 2018, 11:30:20 AM
by BaDshaH786
Last post October 08, 2018, 09:37:28 AM
by BaDshaH786
