Marvel's The Punisher | Czech Republic | 120 pulsaciones por minuto
+ ShareSpark.net »  :::: Miscellaneous » Mobile Downloads » Android Applications
|- HUAWEI EMUI - ICON PACK v1.6 [Patched]
Electroncs Sale
October 08, 2018, 04:02:06 PM
  • Legend Member
  • Thank You: 1318
  • Topics: 877
\HUAWEI EMUI - ICON PACK v1.6 [Patched]
Requirements: 4.1 and up
Overview: INFORMATION:
* 3790 icons with a resolution of 2K SuperHD + (360x360) pixels!
* 3700+ supported applications!
* 40 HD wallpapers with a resolution of 2K (1440x2560) pixels!
* The first Icon Pack in the world, EMUI Style, High Definition!
* Each icon Designed with extreme care in detail!
* Triple Rendering Icon process!
* Automatic Masking for applications icons missing!
* Dynamic Calendar App for stocks & Google Calendar!
* Requests Free icons Missing directly through the application (3 for each release)!
* Updated periodicals are guaranteed!
* Help, support and information on new future projects and development
ABOUT US:
• This icon pack must be applied to a custom startup. Pixel Launcher, Google Now Launcher and any other launcher that is preinstalled on the device does not support Icon Pack (for ZenUI Asus, LG Home, Home Xperia Except). There's no way to apply the launch theme, which does not allow you to change the icons. For this, please check before your launcher or ensure the startup compatible boot !!!
• With the new Android 7.0 operating system Nougat, LG has eliminated the Home icon support for external packages and does not support a standard set of icons;
• To fully control the size of the icons, you must go to the SETTINGS of the LAUNCHER / ASPECT switch off and "normalize the ICONS" ... The required action on the NOVA LAUNCHER (and all other starts that provide this function) as icons has already normalized and do not require this option ; Otherwise, you could end up with significantly smaller icon sizes!
COMPATIBILITY:
They are compatible with most of the main launcher on the PlayStore,
ABC, Action, ADW, Apex, Atom, Aviate, GO, Holo, HoloHD, ITOP, KK, Lucid, M, Mini, MN, New, Next, Nougat, Nova, S, Smart, Solo, V, ZenUI, zero.
However, it can be used with many others that support the launch icon packs, but are not specified inside the application itself, such as arrow, ASAP, Evi, Cobo, line, grid, N, Peek and Z Launcher, with Xperia Home and CyanogenMod Theme Engine, is applied directly to the SETUP MENU used by the LAUNCHER TOPIC / ICONS SECTION;
Compatibility with the LG HOME launch pad is not guaranteed (should work up to Android 6.0, but I can not personally verify), you can not turn to the Samsung, Huawei, Nubia, Meizu stock launcher ...
Icon Pack was tested personally smoothly:
NOVA grenade launcher;
APEX grenade launcher;
EVIE grenade launcher;
ACTIONS LAUNCHER 3;
HOLA grenade launcher;
YANDEX grenade launcher;
ZEN interface grenade launcher;
Special thanks to D Mahardhika for CandyBar.
WHAT'S NEW
- 50 new icons;
- 15 new wallpapers;
- 3840 total icons;
- 3800+ applications;
- 55 Total wallpapers with 2K screen resolution;
- A new mode of request icons for receiving a request;
- Added a tab with new icons inserted for each update;
- Updated and optimized Xml and Java codecs;
This app has no advertisements
 :download:
Last post June 15, 2014, 02:20:57 PM
by -Ð@Rk.ÐèVi£-
Last post July 08, 2014, 10:19:47 AM
by -Ð@Rk.ÐèVi£-
Last post July 11, 2014, 11:29:41 AM
by -Ð@Rk.ÐèVi£-
Last post December 26, 2017, 04:46:47 PM
by deepak.yadav
Last post August 01, 2018, 08:19:32 PM
by shahzaibjaan
