El secreto de Puente Viejo 1x1931 | AutoMate - Car Dashboard v2.0.1 APK Mod | Radiant Episode 2 Subtitle Indonesia
+ ShareSpark.net »  :::: Miscellaneous » Mobile Downloads » Android Applications
|- [MULTI] File Commander Premium 5.0.18557 [Multilingual] [Android]
100% Bill Offer
October 10, 2018, 10:16:34 PM
  • Team SSX
  • Special Member
  • Thank You: 122
    18.2%
  • Topics: 494
  • Upgrade My Reputation
Description:
File Commander is a universal file manager that allows you to process any files on your Android device with a simple and intuitive interface. In addition, you can perform operations with image libraries, music, videos, documents, and rename, delete, move, archive and send files with just a few clicks.
The latest version takes full advantage of Android N, offering a logon profile option that helps you save your settings on different devices, a new safe mode in which you can encrypt and hide your files from other users, and a disk analyzer that helps you identify files that take away you have free space.
Features and features:
Screen sharing is a convenient way to share your screen with other devices on the same network.
The logon profile will help you save the settings of your program on different devices.
Libraries for music, images and video files, as well as new sections for archives and documents.
Sorting by location: Cloud accounts, network addresses, local files and downloads.
Convenient management of external media, such as microSD cards and USB OTG-storage (if supported).
Transfer files to your PC - Now you can manage files and folders even more easily directly from your computer.
Now you can access the network resources of Windows / Samba, FTP / FTPS servers and remote data exchange (for Sony Xperia devices).
Support for cloud services: Google Drive, DropBox, Box, Amazon Cloud Drive, Microsoft OneDrive and SugarSync.
Pair with nearby devices using Bluetooth.
Convenient file sharing with many sending options.
Fully customizable home screen with quick access tiles.
Quick search for device files using local search options.
Manage your files using the operations of cutting, copying, pasting, renaming and compressing.
Quick return to the place where you left off using the "Recent Files" function.
Transfer file operations that are time-consuming, to the background, while continuing the current work.
Premium features:
Safe mode allows you to hide and encrypt files and folders, making them invisible outside the File Commander.
Quickly view all of your files and folders using the Storage Analyzer feature.
Bookmarks for files and folders.
A recycle bin that allows you to delete and restore files.
Access to hidden files and folders.
Lack of advertising.
Features of fashion:
PREMIUM features unlocked;
All ads calls from Activity removed;
Gift ads icon with mobi apps removed from toolbar menu;
Convert files Unlocked;
No ads while convert files process;
Analytics disabled;
Send anonymous stats disabled by default;
Drive cloud & backup works;
Optimized graphics / Zipalign.
Release Info:
OS: Android 4.1 and up
Language: Multilanguage
http://openload.co/f/XOerrCZLfNo/File_Commander-Premium-v5.0.18557_mod.apk
http://bdupload.info/cm3pm8ype42v
http://www.indishare.me/tdxxij7ijvcw
http://userscloud.com/uy3at8zfhrsj
Last post January 01, 2014, 10:57:41 PM
by tata
Last post February 06, 2014, 07:47:39 PM
by ıllıllı αнʍє иυя ıllıllı
Last post June 15, 2018, 10:59:02 AM
by kiteflyy
Last post October 05, 2018, 04:11:25 PM
by BaDshaH786
Last post October 10, 2018, 04:08:34 PM
by BaDshaH786
