Les Espions da Coté 2016 | Documentation | Religious
+ ShareSpark.net »  :::: PC Applications and Games » PC Applications
|- Arturia Jup-8 V 3.3.1.1782
100% Bill Offer
October 12, 2018, 03:02:55 PM
  • Royal Member
  • Thank You: 1
  • Topics: 893
Arturia Jup-8 V 3.3.1.1782 | File size: 58.8 MB
Jup-8 V is a powerful addition to the family of analog synthesizer recreations by Arturia. Offering the unique sound palette of the Roland Jupiter 8, this virtual version is a sound designer's dream.
This was the flagship synth that put the Japanese manufacturers on the map as serious competitors the early '80's. With its colorful user interface and great sound, the Jup 8 scored a hit among musicians the world over.
Crystal clear fatness
The original instrument was known for its lush pads and haunting leads, its ability to split and layer sounds and its flexible arpeggiator. Jup-8 V not only provides these original features, it created an original sound that is respected to this day.
Innovative sounds
From its gorgeous basses to floating pads and lush strings; our Jup-8V has a sound as big as the planet Jupiter.
Out of this world innovation
While the original was amazing we wanted it to be mind blowing.
We added the ability to patch effects into the voice path further expanding the sound pallet and then added a full function step sequencer and a bold new modulator called the 'Galaxy'. These new innovations take this product beyond Jupiter and back.
Main Features:
More than 500 high-quality, innovative presets
Up to 32 voices of polyphony
The same unique audio structure as the original synth: 2 oscillators per voice, 2 LFOs, 2 filters and 2 envelopes
Unison mode up to 4 voices
Two simultaneous voice-level effects (serial): Chorus/Flanger, Phaser, Distortion, Parametric EQ and Ring Mod with flexible routing options
Two simultaneous Patch-level stereo effects (serial): Chorus/Flanger, Dual Delay, Phaser and Reverb
Performance-oriented step-sequencer
Galaxy: an innovative module for advanced LFO modulation capabilities
Keyboard split and layer
Configure external MIDI control quickly and easily
Whats New:
New Features
KeyLab MK2 Integration
Clicking on the preset browser "Clear All" button now scrolls back the result list to its top
Improvements
Reworked preset leveling and consistency
Bugfixes
Reworked effects tooltips
Sequencer step indicator doesn't feature two step #4 anymore
Chorus Feeback and Tune Delay knob are no more swapped
Effects rate tooltip is now displayed with a correct unit
No more crashes when using a sample rate above 96 kHz
No more crashes when changing effects types
User MIDI configuration is now properly recalled when loaded from an external file
Fixed an issue where you had to click twice on the empty MIDI configuration to properly select it
Default MIDI configuration is now properly working
No more white flash when resizing our instruments inside macOS applications in AU
Various Komplete Kontrol / Maschine improvement
No more crash when a "Song Select" message is received
No more cracks and glitches appearing when modifying effects dry/wet parameters
User preset saving feature is now working properly
No more duplicated presets
Live 10 doesn't crash anymore when browsing preset from AU version
Resizing the plugin window don't open the export bank popup for some users anymore
No more crash when switching instruments on a track in FL Studio on macOS
HOMEPAGE
http://www.arturia.com
Download From Rapidgator
http://rapidgator.net/file/fef870f62efeda860cc9884f6a7cf499/BaDshaH_Arturia.Jup-8.V3.v3.3.1.1782.CSE.rar.html
Download From Uptobox
http://uptobox.com/7dlih8rwjmbq
Tags: arturia
Last post October 12, 2018, 12:57:42 AM
by BaDshaH786
Last post October 12, 2018, 12:35:09 PM
by BaDshaH786
Last post October 12, 2018, 12:38:47 PM
by BaDshaH786
Last post October 12, 2018, 12:43:43 PM
by BaDshaH786
Last post October 12, 2018, 03:13:39 PM
by BaDshaH786
